weight (bgp-neighbor-config)
Configures a weight for all routes
learned from this BGP neighbor. Weight is used to decide the preferred route when the same
route is learned from multiple neighbors. The highest weight is always chosen.
- Service Platforms — NX9500, NX9600
Parameters
weight <0-65535>
weight <0-65535> |
Specifies a relative weightage for all routes learned
from this neighbor
- <0-65535> – Specify a value from 0 - 65535.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
weight 10
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
bgp neighbor 192.168.13.99
remote-as 100
advertisement-interval 100
peer-group eBGPPeerGrp1
port 21
strict-capability-match
timers connect 20
timers 20 40
allowas-in 10
attribute-unchanged as-path
capability orf prefix-list both
default-originate
description neighbor "This neighbor is an external AS neighbor"
disable-connected-check
dont-capability-negotiate
ebgp-multihop 20
enforce-multihop
local-as 20 no-prepend
maximum-prefix 400 50 warning-only
next-hop-self
override-capability
passive
password neighbor eBGPneighbor@300
remove-private-as
route-server-client
send-community both
update-source 192.168.13.1
weight 10
